I took it that way, but was commenting that "usually"(well, never in my case) does that gasket properly line up with all 4 ports on the head. They aren't as far off as the ports are in the pic of the manifold though.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
