The flow numbers along with the modern combustion chamber should really make this head worth looking at. Even if the ported eddy matches the flow it should still be at a disadvantage. Can't wait to see some results in running cars. Thanks for the info Dwayne.
Getting old just means you were smarter than some and luckier than others.
