Oh, I know the fel pro paper gaskets aren't right.
If I stack two of them, numbers facing "out", line the bolt holes up as good as possible, the port mismatch is worse on one end than the other, but is as bad as about .060".
I agree that "if" the TF port to bolt spacing is in fact based in that gasket, then it isn't correct.
It certainly looks like azzkikr's head lines up nicely with one of those gaskets, so it would appear that at least one head is a match for that screwed up gasket.
I would certainly hope that TF did more than just use a gasket to figure where the ports should go,and would use known factory dimentions for the heads, that being said it would also seem to me that Fel-Pro might want to look at their die's and see if there is a problem there, after all I would wonder how many 100's of 1000's of gaskets they have made and how many time's they have been rebuilt over the years.
