Page 23 of 45 1 2 21 22 23 24 25 44 45
Re: Trick Flow heads [Re: M_D] #2040375
03/28/16 12:56 PM
03/28/16 12:56 PM
AndyF Online content
AndyF  Online Content
Originally Posted By M_D
Andy, that's a nice looking piece, it should be useful too. Instead of wondering how well the valve train is being oiled it can be verified without running it until parts are either smoked or survive the test of time. Thanks for posting a finished picture.
Yeah that was the idea. And since the local engine guy builds a lot of Mopar big block engines I'll loan him this valve cover so he can use it for dyno testing and engine break in. A lot of times customers bring in random valvetrain parts and we might be able to solve problems up front rather than down the road by double checking the oiling before the engine goes out the door.
Re: Trick Flow heads [Re: AndyF] #2040445
03/28/16 02:55 PM
03/28/16 02:55 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Any chance of trying out the TF hyd roller cam? It's smaller than you have been using, but I curious as to how much power it really can make.
Re: Trick Flow heads [Re: fast68plymouth] #2040492
03/28/16 04:00 PM
03/28/16 04:00 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Andy - another cool AR product with the clear valve cover. The ported M1 intake looks awesome! Looking forward to the results vs the untouched M1.
2 kids and a dog
Re: Trick Flow heads [Re: AndyF] #2040679
03/28/16 09:17 PM
03/28/16 09:17 PM
In a house near you
Street Monkies Offline
In a house near you
Who's rockers are those?
Re: Trick Flow heads [Re: Skeptic] #2040682
03/28/16 09:20 PM
03/28/16 09:20 PM
I don't think I'm up for testing that cam. It is 20 degrees smaller than what I'm currently running so I think it would kill off a ton of power. Probably be a smooth running tire frying monster in a street car though.
Re: Trick Flow heads [Re: AndyF] #2040706
03/28/16 09:38 PM
03/28/16 09:38 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
No problem, They claim 620 HP with the TF heads and that cam on a 10.5:1 440.
Re: Trick Flow heads [Re: AndyF] #2040803
03/28/16 11:09 PM
03/28/16 11:09 PM
The Trick Flow intake showed up today. Nice looking part. It is 1/2 inch shorter than a Victor 383 so that might help some guys with hood clearance issues. Also, the TF doesn't have the "eyebrows" in the plenum that make the Victor intake look so awkward. I'll get it on the dyno in the next couple of weeks and we'll see how it does.
Re: Trick Flow heads [Re: Skeptic] #2040807
03/28/16 11:14 PM
03/28/16 11:14 PM
I believe their 620 HP claim. I bet that cam in my 470 would also make about 620 hp. I'm making 685 hp with a solid roller that is 20 degrees larger as well as a Dominator carb. If I used their cam, intake and carb I'd probably be fairly close to 620 hp also.
Re: Trick Flow heads [Re: AndyF] #2040835
03/28/16 11:52 PM
03/28/16 11:52 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
yeah Andy, whos rockers are those?
Re: Trick Flow heads [Re: fast68plymouth] #2040981
03/29/16 04:50 AM
03/29/16 04:50 AM
Jamie McGrath Offline
Those rockers are made by RAS.
Re: Trick Flow heads [Re: fast68plymouth] #2041112
03/29/16 12:32 PM
03/29/16 12:32 PM
Yep, those are stainless steel investment cast rocker arms from RAS. I don't think they are available anymore. I think they were the very best shaft rocker arms ever made for BB Mopars but they were expensive and rarely in stock. I used to have several sets of them but I've sold everything off but this last set.
Re: Trick Flow heads [Re: fast68plymouth] #2050038
04/08/16 10:12 PM
04/08/16 10:12 PM
The porting that Wilson did on my M1 intake picked up 30 hp. Engine made 715 hp this morning using the same 1050 Dominator that I was running before. Gasket match still isn't perfect so there is probably a little more power hiding in the combo.
Re: Trick Flow heads [Re: AndyF] #2050041
04/08/16 10:22 PM
04/08/16 10:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Nice, Wilson did a great job. Did the Peak HP rpm change as well? And did you throw on the trick flow intake on afterwards to test that too. I know I would of had to. up
Re: Trick Flow heads [Re: fast68plymouth] #2050079
04/08/16 11:42 PM
04/08/16 11:42 PM
No the peak rpm is not moving up. Best pull was 715 hp @ 6500 rpm so the engine seems to be "tuned" for that rpm and isn't changing. I was hoping that the ported intake would move the rpm peak up a few hundred rpm so the power numbers would move up but it didn't happen.
Re: Trick Flow heads [Re: fast68plymouth] #2050105
04/09/16 12:37 AM
04/09/16 12:37 AM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Impressive numbers.
Was there a gain in leak TQ as well?
Is the TF intake going on next?
Did you get another 4500 carb to try? (I can't recall if that was part of the plan)
Re: Trick Flow heads [Re: fast68plymouth] #2050109
04/09/16 12:42 AM
04/09/16 12:42 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I like the headers what size are those? They should up the numbers some.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trick Flow heads [Re: fast68plymouth] #2050376
04/09/16 01:35 PM
04/09/16 01:35 PM
Originally Posted By fast68plymouth
Impressive numbers.
I tried two Dominator carbs. A 950 and a 1050. The 1050 carb made 10 hp more than the 950 carb.
I did also try the new Trick Flow low deck intake. This is a very nice intake, I think it is a better design than the Victor since it doesn't have the big eyebrows in the plenum that the Victor has. I used a new 1050 AN carb from Quick Fuel. This combo made 690 hp @ 6500 rpm.
Re: Trick Flow heads [Re: fast68plymouth] #2050400
04/09/16 02:20 PM
04/09/16 02:20 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Pretty impressive gains with the Wilson M1. Almost makes it worth the money smile
2 kids and a dog
Re: Trick Flow heads [Re: fast68plymouth] #2050457
04/09/16 04:10 PM
04/09/16 04:10 PM
The engine builder I work with does a lot of 420+ inch SBC circle track engines and they typically see 20 to 30 hp increase from intake porting. The circle track guys tend to get their intakes ported but the drag race guys don't.
I'm thinking about getting the Trick Flow intake ported. I'd like to get that combo up over 700 hp also. I think the Quick Fuel 1050 carb is capable so it is just the intake that needs a little help.
Re: Trick Flow heads [Re: fast68plymouth] #2050472
04/09/16 04:33 PM
04/09/16 04:33 PM
So. Burlington, Vt.
So. Burlington, Vt.
Did you try the 1050/4500 on an adapter, on the TF manifold?
The TF intake 1050/4150 combo was 5hp better than the unported M1/4500 combo?
