Is that 1050/4150 one that has the baseplate that will fit either 4150 or 4500 manifolds? If so, did you try it on the other intake?
yes, the QF carb will bolt to either a 4150 or 4500 intake but it doesn't exactly work on a 4500 intake without some other fixes so I didn't run it that way. That would be a good thing to test at some point.
