John,
There was not a price increase. Cost is set to be $4295.00 including shifter mechanism and linkage.
Thanks,
Jamie
Thanks for the correction on that Jamie , I didn't have the time to go back looking for it , very reasonable price for what you are offering .
For anyone wanting to compare price on something somewhat comparable the Richmond Super Street 5 speed = $4,370.80. In comparable, I mean built in USA, good materials, etc.
http://www.summitracing.com/parts/RMG-7030518B/
And no, it is probably not a bolt in...
I have a Richmond 5-speed in my car and it's FAR from being a bolt-in transmission.Also add about $400 for a shifter and linkage,another $400 for a new longer driveshaft and turbo 400 yoke,entire new custom made crossmember and mount,cut and box your torsion bar crossmember,some sort of custom made speedo cable...the list goes on and on and if you can't do all the fabrication and welding yourself I would charge at least $600 to do the swap
Now take all that into consideration when weighing your "OPTIONS" for a 5 speed
Jamie has created the ONLY true bolt in 5-speed
Now all I have to do is save up a few grand more and I will enter the list to get one if there are any left
Gus
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
