Originally Posted By Grizzly69
So...The cost of the entire set up to convert a 69 B body With a 472 Hemi from an automatic is how much ?
Pretty sure it's around $5k just the trans.
complete conversion kits...I think you can find a lot of parts used. I think the auto-x-member will work w/this trans.
Just get a big-block bellhousing, pedals, TO bearing, clutch just about anywhere.
Then there's the hump you have to weld in.
