JD,
We will do you one better, the new shifter accepts YOUR stock handle. We are making the shifter in both tower arrangements to accept both press in and bolt on handles. So, you will re-use your handle. You can simply change the ball to a 5 speed ball or the lens in a pistol grip to a 5 speed pattern. OR, for stealth, you don't even need to change the ball or lens. Either way, it is YOUR choice. We are not ramming this down anyone's throat that you MUST use our handle at an additional cost.
We wanted to make this as easy as possible for people. Plus, if you just dropped the money on rechroming your handle, you didn't "waste" that money. You will still be able to use the handle. Now, if anyone doesn't have a handle, we can also provide one, but it is not necessary.
These little details just put this product head and shoulders above ANY other option out there as being a TRUE bolt in with NO Mods. So, you won't look like this guy in order to put the transmission in your car!
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
