Micm, My car is still on the rotisserie and winter is here. Probably no road tests until next summer but Ill be on it all winter getting ready. I might just put it in my other Duster to try it out sooner as I am just as eager as you are to play with it
Scott, the Outlaw DennisH says after seeing you ride his clutch all the way up Mulholland drive, he's taking bets on how long your throwout bearing and clutch are going to last. He says he gives it a month or two tops!
He looks right at home. Probably more use to the back seat.
“So if it’s on the internet it must be true”
Abe Lincoln
