I second that, well said Jamie. As a purchaser of as I understand it one of the first 10 units, we worked through our issue. I now have about 2000 miles on mine since the break in process, about 1999 very hard miles and have had absolutely no problems at all with the unit. For you guys waiting for yours I can assure you that it is well worth the wait, a 4:30 geared small block a body with a direct fit 5 speed, it doesn't get much better than this!
