The other goodies. The shifter lever rods come fully adjusted by Jamie, and he was very clear about using electrical tape etc to stop them from turning on the adjusters prior to installation.
Kit also includes a longer speedometer cable which I will lube prior to install.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
