so how much power can this thing handle? close to stock or can i slap it behind a twin turbo making 700+ HP? Are the ratios any good for road racing? "
LotsS!
Btw .. If you gotta mopar with twin turbos making
Only 700 hp thats pretty sad...
Do you have a twin turbo car?
No i'm in the planning stages hence the very uninformed question. I see this is a getting a lot of attention and i know transmission can be a overlooked aspect of the car. sooo i figured this might be a good place to look.
i already like that can that i can mount it with stock shifter and mounts and drive shaft. so thank you for a link to the PDF ragtopdodge.
I have also been told the stock 440 block can only take so much power/horse power. I wish i could find the post talking about it.
any ways i'll print off off the PDF and see what the old man thinks.
