Fitment in 66-70 B Bodies has been handled. It fits. The plan is to release the unit in 4 months. I assure you that we are working dilligently to finish the unit. However, I will not release anything until it is ready. I totally understand if you don't want to wait and I respect that. If you decide to go the Keisler route, I wish you luck and hopefully you don't have to cut your floor.
Thanks,
Jamie
I may wait the 4-months.
I am ready to drop the new 505" stroked 440 into the '69 Coronet and I could just use the 4-speed that I have in the meantime, but it needs new seals and linkage bushings.
Changing the transmission out later is not a big deal now that I have a lift and trans jack. I just would like to get the overdrive trans because the car has a 4.10:1 dana60.
