Quote: why would you need to buy another clutch setup when you can just buy another disc , assuming the pressure plate is still good ?
Discs, not disc.
are 2 discs $1200 ???
What is your point?
I'm expected to buy a clutch, drive my car about and then purchase replacement discs for said $1200 clutch setup after the 18 spline transmission is finally released.
I don't like wasting money, throwing away two expensive discs is not my idea of a good time.
