Quote: thanks for putting out a very needed item for our cars...
can you post the 1st to 5th gearing ratios
thanks
From Page 2 of this thread....
Quote: I will try to answer some of the questions I saw. At this time, no 23 spline. If we do that, we are going to lower the torque capacity of the trans significantly. It just doesn't make sense to spend more money to tool up for a weaker design.
There are tapered rollers throughout the trans. Input shaft, mainshaft and cluster gear front and rear. Gear Ratios are
2.64 1.92 1.40 1.00 .70
Weight is 105 lbs
Thanks, Jamie
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
