Quote: Sorry, I have'nt read all the posts here... Are you offering Big block and small block bell housings in the kits or are those going to be separate costs?
Also I keep hearing A-Body and E-Body... Are there going to be 68-74 B-Body kits? For both Big block and Small block available (all years 68-74)?
It uses the stock bellhousing so if you already have a car set up for manual trans it will bolt right in .
I'm pretty sure he has a 69 Down B body tail , 70 up B body uses the same tails as an E body .
Gotta have the hemi 4 speed set up though to bolt right in (18 spline) i believe.
