Torque rating is 650 ft./lbs. However, the design capacity for the unit is 750+. I am rating it at 650 now. As testing continues, it is likely that we will be able to raise this number. However, I am not going to go out and say that it can take "over 1000 ft./lbs of torque" like "others" have done. I would rather rate it conservatively and increase the number later than end up with a bunch of broken stuff.
