Hey Alan...with all of your experience (and our shortcomings with trying) have you figured out a way to change the date codes on NOS tires?
The answer is simple Dave....You should know from the past...Your company makes exact replicas of items you've needed in the past so why not fire up the old tire making machine, find some correct date code rubber pellets and make your own exact copies of the tires with the dates you need...Sounds simple to me
