Quote: That is a fantastic car. I'm glad you used a Valiant as your choice of cars since it will probably never happen again.
Now, the true test to see how accurately you performed the restoration. Since you have all those comparison before and after pictures you should run the car another 11 or 12k miles and see if the car looks the same as it did when you started.
Does this mean we would have to start all over again when the test is complete?
