Quote: In regards to the engine paint. What color or mix code did you use?
Mike Afflerbach
We did not use a "standard" color mix code. The paint we used for the engine/car (as well as every other painted component) was Spies Hecker. For the engine, we found an extremely clean area that was preserved quite well. We kept mixing and tinting until we came up with a perfect match to that sample. We used this brand on my other cars and they look like they were painted last week. It does not even discolor or burn off from the heat of the engine! It is a very durable product.
