So, after another month of traveling I'm working on the car again this weekend.
I'm hoping to start the car without the exhaust for a short period. Emil made me do it by showing me his car running in a semi assembled state.
I'll bench test the injectors and coils, disconnect it all and turn it over for an oil pressure check. Once it's showing pressure, I'll see if it will high idle for a little while and maybe get some heat into it.
