More rotor offset is great for clearing fixed calipers but it can close up clearances on the back side of the knuckle. You have to start looking at clearances with the tie rod, ball joint, and other suspension bits.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
