Quote: I don't know by part number, but I know by application.
The alternator is a re-manned 05-08 5.7 car unit and my ps pump is an 03-08 5.7 car.
I'll use an external reservoir on the PS pump. Just factory stuff mounted to the fender. The easy thing to do would be to get a Jeep SRT8 Powersteering pump, with the built in reservoir...but I've not come across one for thr right price yet.
Alex,
Did you check the pressure output of the PS pump against the steering gear you are using?
New and old are not always compatible.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
