Quote: That's the milodon peice for the dipstick and it's just the normal pan. 7 quarts? Weve determined that the road race pan probably isn't needed for what I want to do, even with sticky tires.
31000 listed as 6 quart. I run up to 7-ish. I log oil pressures and haven't had an oil pressure drop.
The 31003 RR pan is listed as 7 quart.
Moving on ....
What do you spin yours up to Wade...I'm wondering if mine will be OK to 7100 without an accumulator......
