Does the VVT driver on this properly control the cam phaser on '09 up engines or is it pretty much just fluff? That would make this a very good prospect in that area. If not maybe it could be used for MDS since that functions similar to VVT. Not that I am concerned with that.
The box has the capability to control VVT, etc, but AFAIK, no one has done that or even tried to with a Hemi yet.
same with the knock control...
What wade said.
Just because it is there, doesn't mean it is compatible with the hemi...yet. There are always expansions looming over the horizon.
And I'm less than $1500 for EFI and fuel system.
The fact that gets me everytime is when someone says they want to save money by going carb on a motor like this.
Even if you have nice carb, the MSD ignition controller is still $800 and then you may or may not have to do anything with your fuel system.
