Quote:Quote:The fact that gets me everytime is when someone says they want to save money by going carb on a motor like this. Even if you have nice carb, the MSD ignition controller is still $800 and then you may or may not have to do anything with your fuel system. That wasnt my reason...mine was appearance and that I couldnt face the EFI learning curve.. But you should be fair with your costings Alex.... I didnt have to swap out my fuel pump, fuel line, use a fuel accumulator or put on a return line...But yes....its never going to be able to run the camshaft LSA you EFI guys can....which dictates how much duration I can get away with.
