I tried the tin Milodon pan with the factory gasket..ended up with leaks - ended up combining the factory gasket with the milodon cork gasket and it sealed like Fort Knox....
This was after I had to drop the cross member to remove the pan...
Check your pinion angle with those TTI mounts as well......
