I found radiator hoses for a B-body with a 26" radiator opening and a Champion Hemi swap radiator. Just universal gates green hoses and they fit really well. I'll post the numbers up tomorrow.
Oil temperature and oil pressure gauge is in. Had to take the alternator off but it was worth it. Cooling fan brackets are almost mocked up. Just need a little bit more work.
Also, my spring swap is complete. The car is sitting really nicely with the 2x right side XHD springs, 2" steel lowering blocks and the AR engineering front spring hanger set on the -1" setting.
