Quote: Why aren't you using armor sheathing on your break lines?
Idk... What would be the downside of not running them? All the lines are custom. I haven't seen any armor sheathing in stores.
You run the risk of road debris hitting line and either kink it or causing a rip. Had it happen to me, luck of the draw I guess. Lost my front brakes. You can buy it from Finelines.
Lost the front brakes on my 67 Coronet from not having the armor on the line. It happened a few weeks after I did the repair thankfully at low speed. Since then every car I do gets new lines.
56 Plaza 63 D100 step side 67 Coronet, 68 Roadrunner, 69 Super Bees, 69 Coronet 500 convertible, 70 Roadrunner Post, 79 D150 360, and a severe case of Mopar a,d,d
