Looks good, I still don't know if I will have any exhaust or wheel rubbing problems since I made the same switch as you. I went ahead and bought these though to raise up the rear a bit in case they do. http://www.summitracing.com/parts/mrg-1288 You can get them from probably any parts store. mr gasket part # 1288
