Sounds like your master cylinder is going out. Put the car up on all corners take all the tires off and check the brakes. I've had new wheel cylinders leak also so you might want to check the old ones. Also you could have a brake hose that is bulging from a blockage.
When you have the car up find the gear selector on the transmission, unhook the selector lever rod and move the gear selector all the way in park and adjust the rod to he selector.
You probably need to adjust the drum brakes also when you pull the drums. Look for he star wheel near the bottom of the backing plate.
Don't get discouraged its probably only the master cylinder a fix that takes less than an hour.
56 Plaza 63 D100 step side 67 Coronet, 68 Roadrunner, 69 Super Bees, 69 Coronet 500 convertible, 70 Roadrunner Post, 79 D150 360, and a severe case of Mopar a,d,d
