So here's all the progress of the weekend. Been working slowly but we're pushing through little by little. Got the firewall welded and grinded a little. May do some more work on Monday and work with the pedal assembly as well. I'm going to probably rebuild my calipers since the seals are bad. Also may get new wheel bearings as well since I've practically rebuilt the entire brake system.
Also took out some of the AC stuff from the engine compartment to reduce weight and clean it up a little.
Went to the tire shop on Friday to look at tires. I'd like some 17's but don't know if my axles can handle them in the rear. Also looks like I'm going to need a skinny front (was hoping for something like a 245 or more).
Here are my progress pics...
Hubs and studs:
Going to need a rebuild and a fresh coat of black paint:
