Thanks Wingcars, as I remember there were problems with the way the Superbird wing fit on the Charger. There were gaps along the outboard edge of the wing base as can be seen in the center picture above.
Here is the car a few years later. If you look close, the quarter panel damage caused by bending the wing uprights over can be seen...
Allen
