Quote: I was born and raised in central PA, raced at Beaver Springs, moved to the southwest in 1988, so I'm not close. Thanks for the offer. Is there an intake that would serve double duty without too many compromises? When finished, would you share details of your sheetmetal intake?
Your only real choice (unless you have the $$ for a Wilson) is the stock 6.1 intake. Do yourself a favor and match up the intake gasket to the intake. Assuming you are running 6.1 heads, you will see that the intake could really use the removal of some material where it bolts to the head, just use the gasket as a reference. If you don't feel up to this task yourself, Dave Weber offers this service at Modern Muscle.
