Quote: So if the info from the 6.4L Apache crank thread holds true then using a 5.7L block(more of them),6.4L crank(C.I.D.),Eagle heads(flow and CR),DP or Eagle intake,good rods,5.7L 9:1 pistons (offset Eagle heads)and a custom cam to match a guy could put a pretty stout Gen 3 togther for what I would say is VERY reasonble cost.
Yes or no? :shruggy
This is basically what i was thinking about doing!
Zippy and anyone else who might know, what kind of power could a person expect to make with a combo similar to this?
HEY HANDS OFF LOL there is only one crank in the mopar inventory.hopefully they make more. As for the power I think a .020 over 5.7 with 3.72 crank, would result in the same CID as a 6.1. So power wise should have more tq and a little less HP.
