Here is a quick run down 6.1 block 4.065 I bought the Manley rotating kit 4.050 stroke 48lb crank Manley H beams 2.00" x 6.125 .927 pin manley flat tops 11.5 to 1 LSM cam .400 LS lobe(.640 ) 266/272 @.050 114 LSA hydraulic roller Manton 3/8 pushrods ATI dampner Charlies 8QT oil pan
CNC ported 6.1 heads from MCH Pac 1219 beehives 150/400 open Sharadon rocker shaft tie bars and collars Drag Pack intake Fast EFI
thats most of it off the top of my head
Dont really know what kinda power its gonna make. Drag Pack Motors make around 625 HP or more at 370" with unported heads.
So who knows what mines gonna make. But I will take all I can get.
My goal when I talked to Jeff at Modern was to make all the power I could and stay with pump gas and a hyd roller cam. Gotta be street friendly
