I have been watching all the threads I can on the Gen III hemi engines. Like I have stated before, I have a 5.7 dirt track experiment engine in the works. I have lots of questions, The first being,,,where can I get some basic info on the engine???...as what is the stock rod/crank capable of producing,,,what are the 'factory specs' for rod length/deck height.etc...so I can do some math on compression/piston pin height /etc..?? Also,,what are people doing for ignition system when going with carb set-up..??..crank trigger system to fire the stock coil arrangement,,,does the crank need a keyway cut into it to hold the crank trigger system accurate,,LOTS of questions!! STILL have not had anybody tell me where they are finding the intake manifolds,,,all I hear is they are pricey,,where are they ACTUALLY available?? Thanks.
If you like drag racing, support your local track.
