Quote: The Hemi 6 Controller works excellent!! It basically uses the same software as the Digital 7 programmable via laptop.
I've run best of 11.05 @ 122mph at 3400lbs. Motor was a stock shortblock, ported heads, PWR cam. I hurt the stock short & blew it up at Monster Mopar, so I have a new motor in the works.
Congrats and sorry to hear you hurt the short block
What were you reving to and which engine 5.7 or 6.1?
6.1 motor...had about 10,000 miles on it when purchased. I left the short alone, ported the heads, PWR 224/228 cam, DP intake, carb. Made peak power, 557HP at 6400, shifted at 6800-7000. Motor melted down at about 6200 rpm, after shift to 3rd gear.
Nice! On the LX/LC platforms and factory trans controller(TCM) we have to shift the cars before 6850 or they go into "Limp Mode". With some of the more rowdy PWR cams we are making power right up to 6900 but unfortunately can't use it.....
Forge the short, maybe a little more compression and cam and you will easily be running 10's.
