No, didnt even try looking. Hopefully Zippy will chime in and give use an update of the availability.
I would like to know who has been running the Aluminum block.
Are they good casting?
Did you ever figure out what happened with your 6.1?
There seams to be alot of 5.7 and 6.1 pushing 2 tons of anchor pretty fast.
As for my 6.1 carnage, the thought is that the stock piston just failed & came apart.
