Quote: Spacer typo error. I found what there were using at comp cams. IMO a spacer for the new block so you could use the older cams would be better for the grass roots racer. Now who has a part # for the PRODUCTION 6.4 hemi?
This weekend i will go to my local dodge dealer and see if they have any part numbers yet??? As of the summer they didn't. The only reason i wouldn't want the spacer is sooner or later when someone figuares out how to use the VCT with an aftermarket cam, IMO would be nice to use...
