The "Hemi Charger" they are rebuilding on the TV show Chop Cut and Rebuild is suppose to be "one of one as stated by Galon Govier on the show if it exist". The only parts they are reusing are the unibody, all the sheet metal including the Roof and some of the Roof supports are being replaced. They have to weld the sections with the body vins back into the new AMD Rad Support and trunk Rail panels. But I am sure if GTS says it is good it will be worth Giant money. Has anyone else watched this show? Am I confused on what they are doing? With that much metal replaced is it considered the same car just because they reused the Vins? I do not know where to draw the line on these rebuilds.
