Quote: the broach is a tool that is put on a slide hammer and pounded thru the bores for lack of a better way of doing it ?
Guess I should have phrased my question a little differently. If lifter bore dimensions are critical to a thousandth of an inch, how many times can you pound the broaching tool through a lifter bore before the tool diameter is no longer in spec?
