Quote: To be brutally honest, his tool (lifter broach) is a simplistic tool, it only indicates or broaches the approximate diameter, the bore could have critical geometry errors and not show up with out more sophisticated measuring.
which was the situation in our case. the bores could have been exactly the desired diameter, and it still would have chopped ANY fast rate .904 cam. the bores werent located properly in the block, which was corrected when the lifter bores were sleeved.
Quote: since one of the good friends I made during this whole EM project had nothing but good to say about Hughes I feel bad about the whole deal.
i was thinking the same thing when i read Daves rant. its like i could picture him sneeking up behind the guy right before he stabbed him in the back.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
