The last I checked, the Enginemasters statements were that when running one of these cams, be sure to check the lifter bores and that it WAS a lesson learned in the end. I wonder how many people out there have one of these oversized lifter bore blocks that are running just fine with another cam.
So, to make Mr. Hughes happy, I will say it in front of all the people right here.. DO NOT BUY one of his cams unless you have had the lifter bores checked and/or resized and bushed But this ofcourse, is from an uN-professional, pea-on "hobbiest", so what would I know?
