Cool... looks like you got a good 3' to play with on the trailer... looks like the truck is squatted a bit.. might want to check the tongue weight.. might want to back them both up a bit... good luck on your trip.. see you there I just pulled the heads off the Rampage to plug the oil supply to the top end... I changed my mind and went with push rod oiling... but they are back on... I just have to put the rockers and intake back on
