I just found this video for reference, https://youtu.be/BHMH8ZFwiZU you can just forward to the part the pumps running and fuel is coming out... If that's the amount and flow of fuel that should be flowing then my fuel pump is definitely bad, I'm almost certain of it but if someone can just check out the video and confirm that's about the type of flow I should be seeing coming out of my lines right before the filter then I think it'll put this dilemma to rest...
