soak the gaskets in wd40 a little while and they should not stick.
and after you rebuild you carb just make sure you do NOT have any WATER/MOISTURE in your fuel tank/line/filter/pump
I just figured this out myself after 350$ of troubleshooting/rebuilding as I had hard starting-no starting and what I thought was vapor locking THEN no ign spark with low power/carb backfire/stalling & exhaust backfire
2 carbs x2 rebuilds
2 ign. systems.
fuel pump then convert to eclectic pump with a return line.
found 1.5 gallons of water in 22-gallon tank when I drained it, flushed it.
complete fix was a can of BG fuel drier!
nothing more disappointing than rebuilding 2 different carbs only to fill them with water/fuel again to finally figuring out the issue and rebuild one a 3x after a tank flush/fuel drier/22 gallons run through it. engine runs great now.
if I had only started by checking the fuel first.
