Originally Posted by moparx
out of curiosity, have you taken the sending unit out of the tank to check for a clogged pickup sock ? shruggy
beer
I have not... Wouldn't that show in the stream coming out of the carb??? In other words there shouldn't be much fuel squirting into the carb if the sock is clogged correct?? The streams into the carb look good...
