I just went on another drive around the block and it's definitely leaking...
It's just hanging there... Not really dripping... I'll wipe it and it'll stay clean until the next drive... The other day it was dripping about every 30 seconds...
The level is a little on the high side...
Edit/update: I went on another drive and the drip seams really inconsistent and I checked the level HOT and it's a little over the Full mark. Since there doesn't seem to be any mechanical issues and there's no irregular noises I will assume it just has too much fluid! It's weird because when I finished rebuilding the trans I added the exact amount required and when I checked it hot it was below the full mark... Not sure what happened, maybe I didn't push the stick down enough the first times... shruggy
The stick kinda snags at the end and the top part at the handle also fits weird...
I will also add that about one out of four times that I checked the dipstick there seamed to be some small bubbles in it and that was today but like I said, no issues that I've noticed.
Anyway, I'll take a little fluid out and hope that's all it was.
