Originally Posted by B300 VanDanage
Quick question carb related...
The divorce choke I have has a wire that goes to a small "ballast resistor"(not sure what it's called actually) but what else is supposed to be connected to the it??? There use to be a bunch of wires that were for smog components that were removed...
That choke wire is supposed to be fed 12 volts so am I to connect a
"Hot" wire directly from the battery??.
That is called a temperature compensating resistor and it is used to regulate the speed in which the choke opens, quicker when it is hot out, slower when it is colder out. Your choke should be wired to that and the other end should only be hot when the engine is running, it goes from the key switch thru the oil pressure sender, which will send juice to that resistor when you have oil pressure. At least that is how it worked on my 87 Diplomat.
As for the serpentine vs v belt setup, the AC compressor has that as part of the clutch assembly, not sure if you can swap them about or not.
